2002 Ford Explorer code PO410
PAUL J STODDARD
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 767,650 MILES
Code PO410 secondary air injection system what dose this code mean and how do I replace parts
Saturday, March 21st, 2009 AT 10:07 PM
P0410 OBD-II Trouble Code
Technical DescriptionSecondary Air Injection System Malfunction
What does that mean?The P0410 code refers to the emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
Symptoms Possibly symptoms include:
MIL illumination obviously
Hesitation on acceleration
Noise from a bad/stuck AIR pump
CausesA code P0410 may mean that one or more of the following has happened:
Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
Blown AIR pump fuse due to freezing up
Possible SolutionsNote: There is a technical service bulletin (TSB) regarding this code for a number of GM models. The TSB calls for the replacement of the AIR pump and the installation of a new secondary injection hose. The TSB can be found on this ACDelco site.
Additionally, if you simply replace the AIR pump the problem may return again (and again). If you replace the pump, also clean out the hoses and replace the one-way check valve. If this is on a GM model that the TSB applies to, follow those instructions in the link above. In a few cases, people have put a small hole in the rubber cover on the pump which allows any water to drain out.
Also, please note that this may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
Replace the AIR pump AND one-way check valve
Test and clean the AIR pump AND test and replace the one-way air check valve
Replace the AIR pump inlet hose
Replace the AIR pump fuse (found under the hood)
Saturday, March 21st, 2009 AT 10:31 PM
