2002 Ford Explorer Clutch not engaging
119,000 MILES • 6 CYL • 2WD • MANUAL
MSTROFPUPTS1962
my clutch is not fully engaging periodicly making it difficult to get in gear when the vehicle is not in motion. it seems the clutch preassure fades in and out randomly. would this be an indication of the slave cylinder going bad?
Sep 18, 2009 at 2:57 PM
  • 110,248 POSTS
It could be the slave or a bad pressure plate. If it gets worse as the engine gets hot, I would go with the pressure plate. If temp doesn't matter, then the slave.
Sep 20, 2009 at 6:47 AM
