2002 Ford Explorer brake lights
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
LWILSO31
My brakelights are both not working after changing the bulbs, changing brake pedal sensor, and checking all fuses. The running lights, parking lights, turn signals, hazard lights all work. Please give me any suggestions you have on whatelse I can check.
thanks!!
May 17, 2009 at 11:41 AM
BMRFIXIT
  • 19,053 POSTS
Does the 3rd light work and if so suspect combination switch
check for power at the brake light switch
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 17, 2009 at 2:14 PM
