2002 Ford Explorer brake freeze
93,000 MILES • 6 CYL • 4WD • AUTOMATIC
SKIPPYGIRL
occasionally a brake will freeze closed after use. bleeding line and prying caliper solves the problem, but need a solution. Is there a history of this with explorer, and what part needs replaced: Is it lines,calipers,or dort on calipers....
Sep 27, 2008 at 2:15 AM
BLACKOP555
  • 10,386 POSTS
cracking bleder doesnt loosen it you have to pry on caliper also? iw oudl suspect you need greese or the caliper has more then likely froze up and you will need a replacement.
Sep 27, 2008 at 3:09 AM
