2002 Ford Explorer bearings
15,000 MILES • 6 CYL • 4WD • AUTOMATIC
TRACY40
we reasently took our truck in to have a front in alingment done on it because when i took my hands off the wheel it would pull off to the side pluse it was making a funy nose up front they told us we have 3 bearings going out does that sound about right or are they taking my money thanks
Mar 25, 2008 at 9:28 AM
BMRFIXIT
  • 19,053 POSTS
you have one bearing per side
so I will get another opinion
does the noise fade away when slight turn to left or right and if so that is a bearing noise
good luck
Mar 25, 2008 at 10:58 AM
TRACY40
are you saying theres only two bearings not three they said the one on the driver side and passanger side and drive shaft bearing or somthing like that the sound is like a humming goming from the passanger side what do you think thanks
Mar 26, 2008 at 12:34 AM
BMRFIXIT
  • 19,053 POSTS
i would change that wheel bearing and hub and give it a road test (its one piece unit)
https://images.2carpros.com/forum/automotive_pictures/99387_bearing_1.jpg
Mar 26, 2008 at 4:11 AM
