We reasently took our truck in to have a front in alingment done on it because when I took my hands off the wheel it would pull off to the side pluse it was making a funy nose up front they told us we have 3 bearings going out does that sound about right or are they taking my money thanks
SPONSORED LINKS
Tuesday, March 25th, 2008 AT 4:28 PM
BMRFIXIT
MECHANIC
You have one bearing per side
so I will get another opinion
does the noise fade away when slight turn to left or right and if so that is a bearing noise
good luck
Tuesday, March 25th, 2008 AT 5:58 PM
TRACY40
MEMBER
Are you saying theres only two bearings not three they said the one on the driver side and passanger side and drive shaft bearing or somthing like that the sound is like a humming goming from the passanger side what do you think thanks
SPONSORED LINKS
Wednesday, March 26th, 2008 AT 7:34 AM
BMRFIXIT
MECHANIC
I would change that wheel bearing and hub and give it a road test
