Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Suspension
Ball Joint
Replace/Remove
2002 Ford Explorer BALL JOINTS
2002 FORD EXPLORER
76,000 MILES • 6 CYL • 4WD • AUTOMATIC
NIGHTBREED77
MEMBER
1 POST
THE RUBBERS ON MY UPPER BALL JOINTS (FRONT) ARE GONE. THE MANUAL SAYS THEY ARE NOT SERVICABLE. DOES THIS MEAN THEY CANT BE REPLACED.
Feb 27, 2008 at 10:58 AM
BMRFIXIT
Experienced Mechanic
You cant service the ball joint as a part you have to replace the upper control arm as a whole
good luck
Feb 27, 2008 at 12:00 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
