2002 Ford Explorer ACUATOR BLEND DOOR
68,000 MILES • 6 CYL • 4WD • AUTOMATIC
DJOWERS
COULD YOUTELL ME WHERE THIS DOOR IS LOCATED? DO I NEED TO REMOVE THE DASH
Nov 22, 2008 at 5:58 AM
DAVE H
  • 13,383 POSTS
yes .. i'm afraid you have to remove the dash to remove this part ..
Temperature Blend Door Actuator
The temperature blend door actuator:
Is located on the heater core and evaporator core housing.
Moves the temperature blend door on command of the temperature control switch.
Contains a reversible electric motor.
Nov 22, 2008 at 11:54 AM
