2002 Ford Explorer AC/Heating Fan/Blower
12,300 MILES • 6 CYL • 4WD • AUTOMATIC
WKCLARK
AC works fine...Max AC only blows out through windshield defrost area. When attempting to adjust blower dial -- internal dampers do not change. regardless of where the dial select is all air is blown out through winshield defrost vents?
Sep 7, 2009 at 1:50 PM
  • 110,248 POSTS
The vents are actuated by vacuum. In this case you are looking for a vacuum leak. Check under the dash and the hood where the supply line attaches. If you have the engine running, you may hear a hissing sound where there is a leak.
Sep 10, 2009 at 1:57 AM
