2002 Ford Explorer Accessory plugs will not work
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
MAB5916
  • 5 POSTS
I have a 2002 Ford Explorer. The accessory plugs (cell chargers, GPS, chargers, etc.) have stopped working. Neither plug will work, front/rear.
I checked the fuses under the dash and could not find any that needed replacing.
Any suggestions or what specific fuse I should look at?
Thanks
Dec 26, 2008 at 12:21 AM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you I need to know if you just have an Explorer, or the Sport, or the Sport Trac. Also I need to know the engine size in liter and the 8th digit of your VIN.
Dec 26, 2008 at 3:14 AM
MAB5916
  • 5 POSTS
I have the Explorer XLT, 4.0 SOHC.
VIN# 1FMZU73K12ZC71001
Thanks
Mike
Dec 26, 2008 at 3:30 AM
IMPALASS
  • 3,112 POSTS
Mike Great job on the info Please do me a favor and look on the driver's door for the attached label and tell me what the date that the red arrow is pointing to The information is asking if it is a late or early model.
https://images.2carpros.com/forum/automotive_pictures/248015_1_129.jpg
Dec 27, 2008 at 2:16 AM
MAB5916
  • 5 POSTS
The date is 06/02.
I pulled every fuse under the dash and under the hood again to double check and they are all good.
Dec 27, 2008 at 5:41 AM
IMPALASS
  • 3,112 POSTS
Hello
Thanks for the info ..you have a Late Production build. You might keep that in the back of your mind for future things.
I know you checked the fuses. The two fuses that control the power points are fuse 7 and 9. I recommend checking them with an ohm meter since sometimes by eye is not totally accurate.
If the fuses are good, then check for 12 volts at the plug ends if you have it at the plug ends then the power point sockets need replacing.
Dec 27, 2008 at 9:01 AM
IMPALASS
  • 3,112 POSTS
Hello –
I was reviewing previous posts and wanted to provide you with this info. Looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
02M01S6
08/31/2004
Recall - Tube Mounted EGR Pressure Sensor Defect
04S20S5
02/01/2005
Recall - Replace Liftgate Glass Ball Stud Bracket/Hinge
NHTSA04V442000
09/09/2004
Recall 04V244000: Liftgate Glass Strut/Hinge Defect
Dec 30, 2008 at 12:47 PM
MAB5916
  • 5 POSTS
It turned out to be a 20 amp fuse under the hood.
Jan 1, 2009 at 5:16 AM
IMPALASS
  • 3,112 POSTS
Hello
Fantastic was it one of the fuses recommended to check or a different one?
The reason I ask is to make sure the manuals are not incorrect
Jan 1, 2009 at 5:34 AM
MAB5916
  • 5 POSTS
Yes it was #7. I replaced # 9 also, just to be safe.
Thanks
Jan 1, 2009 at 8:29 AM
IMPALASS
  • 3,112 POSTS
Hello
Thank you for the update
You have a great New Year!!
Jan 1, 2009 at 9:15 AM
