2002 Ford Explorer A/C COMPRESSOR - SPORT TRAC
MADERA
Air Conditioning problem
2002 Ford Explorer Two Wheel Drive Automatic 103,31 miles
AIR CONDITIONING WORKED FINE PARK VECHICLE FOR 3 MONTHS. TURNED VEHICLE ON AGAIN A/C NOT WORKING A/C COMPRESSOR WILL NOT COME ON
CHECK:
1> CHECKED VOLTAGE AT CONTROL PANEL INSIDE VECHICLE SWITCH - GOOD
2> CHECK FUSES AT 56B (A/C SOLENOID) - GOOD
3> CHECK FUSE AT 10 (A/C CONTROL) - GOOD
4>CHECK VOLTAGE AT CONNECTOR FOR COMPRESSOR - NO VOLTAGE
Feb 16, 2010 at 11:00 PM
  • 75,988 POSTS
Could be low in freon and the low pressure safety switch is preventing the magnetic clutch to engage
Feb 16, 2010 at 11:23 PM
