2002 Ford Explorer a/c
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
RPWALKER
when turning the a/c from normal to max there is no longer an increase in air circulation?
Jul 19, 2008 at 9:28 AM
MASTERTECHTIM
  • 4,750 POSTS
its possible you have something csught in the blend door. look under dash and see which door doesnt move when changing from hot to cold and through all the vent positions. the one that does not move is the recirc door and see if you can get it unstuck if its stuck. or possibly the rod fell off and you will have toresecure it. hope this helps
Jul 19, 2008 at 9:45 AM
