ABS light stays on, had the rear sensor replaced by mechanic the code from the diagnostic computer suggested that was the problem. New rear sensor same problem. also is the outside temperature display available for the XLS trim? At start up the digits are there, but the odometer only shows mileage and trip mileage? I think outside temp is supposed to be there, maybe it was turned off... Thanks for your assistance.
Dec 22, 2009 at 6:50 AM
