2002 Ford Explorer ABS Light on
JASI2570
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 108,000 MILES
The ABS light is on on my 2002 Ford Explorer. I took the a local mechanic who use the scanner on it. He said the rear ABS Sensor is bad and the part would cost about $80 plus labor.
I do most of the work on my car myself. I check with the dealer and the sensor is $48.00.
Do you think this is the problem and is this part difficult to change?
Thanks
Jacob
Thursday, October 8th, 2009 AT 9:26 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Jacob,
If the shop pulled codes and that is what it showed then I would say that is the problem. I am surprised it is so cheap from the dealer though. Anyway yes you should be able to change it yourself with no problems.
Thursday, October 8th, 2009 AT 9:30 AM
