Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Warning Lights
ABS Light
2002 Ford Explorer ABS light
2002 FORD EXPLORER
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
CPOD2
MEMBER
1 POST
analyzer shows no code yet the ABS ligthis is on
Aug 26, 2010 at 8:02 AM
Experienced Mechanic
Are you using the correct type of scanner for the ABS? Have you checked to make sure none of the sensors are damaged, disconnected, dirty, or have wiring damage?
Aug 26, 2010 at 2:01 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
