2002 Ford Explorer 4x4 indicator
2002 FORD EXPLORER
155,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOOCH1215
When you first turn on key and all the warning lights show, it shows 4x4 low on the left. When all warning
lights go out and you start the explorer it goes out, can't get light to come on dash for 4x4 high when buttons are pushed. The explorer does not drive as if in 4x4 low, don't know if 4x4 is working?
Jan 17, 2008 at 8:49 AM
MASTERTECHTIM
  • 4,750 POSTS
you can usually tell if 4wd is working by making sharp turns. the truck will feel like it is binding. do you hear any clicking from under truck when you press 4wd?
Jan 17, 2008 at 8:53 AM
