2002 Ford Explorer 4WD noises
74,568 MILES • 6 CYL • 4WD • AUTOMATIC
JOHNNYFORD
It seems like my 2002 explorer XLS is always in 4WD.
If I switch from 4 wheel auto to 4 wheel high or low there is the same wining noise that changes with speed, Could it be stuck in 4WD?
Thanks
John
Oct 28, 2008 at 12:02 PM
DLOBI
  • 125 POSTS
You could be in 4wd all the time but more likely is that you have a wheel bearing that needs to be replaced. I would have it checked out.
Oct 28, 2008 at 1:16 PM
