HOW DO I CHECK TO SEE IF THE AUTOMATIC 4 WHEEL DRIVE IS ON? ALSO SHOULD IT BE ENGAGED EVEN IN DRY WEATHER?
Sep 30, 2010 at 3:58 AM
✓Experienced Mechanic
The auto 4wd is on all the time. The only way it will engage, however, is when the rear wheels slip. At that point, a speed sensor recognizes that the rear wheels are spinning faster than the front and the front wheels are automatically engaged.
