It is definitely possible, I would check those levels quick before you really damage something, they probably pulled the tranny one and a couple of quarts came out before they realized that was the wrong bolt, and never replaced the fluid, causing your tranny to act up. Ford, especially explorers, already have a reputation for bad trannys so I would not hesitate any longer and check that out
SPONSORED LINKS
Monday, September 29th, 2008 AT 9:56 PM
