1997 Ford Explorer delayed shifting
122,000 MILES • V8 • AWD • AUTOMATIC
ROB BOWEN
My Explorer is having issues with delayed shifting and not going into overdrive. I took it to a trans shop to have it checked but it was not doing it when I got there. It sometimes runs fine and then will start up again. There is also a lown whistling sound when I am driving. No check engine light comes on when this is happening. I was told it could be a sensor problem.
Feb 16, 2010 at 10:37 AM
  • 110,251 POSTS
Hi:
This is hard do diagnose if the check engine light hasn't come on. To me it sounds like a sensor or a solenoid. There are sensors (Speed sensors) that determine shifting / OD... and shift solenoids that cause the trans to shift. I believe one of them are the problem. However, it becomes a guessing game when there is no light.
Feb 17, 2010 at 12:44 AM
