Thanks for the feedback!
2002 Ford Explorer Front Seal Leaks
Suggested Repair
Get a second opinion on the front pinion seal and left front axle seal. Replace actively leaking seals before fluid loss or dirt causes a larger failure; if they are only seeping slightly, monitor the leak and fluid level closely.
Conversation Summary
The owner of a 2002 Ford Explorer recently had a wet, rotted rear bearing replaced and was then told the front pinion seal and left front axle seal needed replacement. The owner asked whether these were the same as the rear repair, whether Explorers commonly have these issues, and whether the work could wait. The expert explained that seals are not lifetime parts and often wear out in groups, that replacement labor can be costly, and that slight seepage may be monitored, but an axle seal leak should not be ignored because contamination can lead to a more expensive failure. A second opinion was recommended.
