How do I install the brake light switch? Please help
ERIKA2976
  • 2002 FORD EXPLORER
How do I install the brake light switch? Please help we tried and now the car won't even go in reference
Friday, June 19th, 2009 AT 5:57 PM
  • 109,896 POSTS
The switch is located on the top of the brake pedal. It just a matter or unbolting and replacing the part. If you can't get it out of park, check to see if the brake lights are working. IT may need adjusted to work. The brake light switch actuates the park lock solenoid. So if the brake lights are not working, you can't take it out of park.
Monday, May 10th, 2021 AT 1:48 PM
