2001 Ford Explorer windows
KKWILES
2001 Ford Explorer
My windows and sunroof won't open
Dec 2, 2009 at 11:53 PM
RICKMAR
  • 170 POSTS
There is a very good chance you have a ** Mega Fuse 30 Amp. that needs to be replaced. FUSES AND RELAYS If electrical components in the vehicle are not working, a fuse may have blown. Blown fuses are identified by a broken wire within the fuse. Check the appropriate fuses before replacing any electrical components. Power distribution box "NOT THE DASH PANEL FUSE BOX" The power distribution box is "BLACK BOX" located in the engine compartment on the drivers side fender up near the firewall next to the power brake booster. The power distribution box contains "high-current fuses" that protect your vehicle's "main" electrical systems from overloads. Always disconnect the battery before servicing high current fuses. Always replace the cover to the Power Distribution Box before reconnecting the battery or refilling fluid reservoirs. The high-current fuses are coded as follows: Power Distribution Box Description 1 60A** I/P Fuse Panel fuses 1, 9, and 13 2 40A** Blower Motor Relay 3 50A** 4 Wheel Anti-Lock Brake System (4WABS) Module 4 30A** Power Moon Roof, Accessory Relay Delay 5 50A** Ignition Switch, Starter Relay 6 20A** Transfer Case Relay 7 "” Not Used 8 20A** Air Suspension 9 40A** Air Suspension 10 30A** PCM Power Relay There are others but there is no need to mention them for they do not pertain to the problem. Mega Fuse #4 30A** is the fuse in question of replacement. >>>>>>>>[175 MEGAFUSE]<<<<<<<<
https://images.2carpros.com/forum/automotive_pictures/433905_explorer_power_dist_panel_fuse_2.jpg
The Power Distribution Box layout is pictured above. Remove the black cover. You want remove **Mega fuse #4. Location >>("Far Left" side of the Power Distribution Box looking down at the box). The second fuse "UP" marked #4 and check it to see if it is toasted (Blown) replace the **30 Amp. Mega Fuse in the #4 slot of the Power Distribution Box with a good one reconnect you battery and you should be good to go. I hope this information helped; Rick
Dec 3, 2009 at 1:57 AM
