2001 Ford Explorer will not start
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
JHUGHES656
some times when i try to start (after it has been sitting for a while) It will not start. It turns over and I just bought a new battery. I will try to statr it then I let it sit for a few minutes and it will start.
Jan 26, 2010 at 2:21 PM
  • 75,988 POSTS
Next time don't wait for nothing,do below immediately to determine whether it's a fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Jan 26, 2010 at 6:07 PM
