2001 Ford Explorer water leaking at transmission
250,000 MILES • V8 • 2WD • AUTOMATIC
AUSSIE39
just had used motor put in four months ago now there is water leaking at transmission look at reciept it says the replaced the transmission torque for 650.00 dollars any answers
Sep 22, 2010 at 10:09 AM
SATURNTECH9
  • 30,869 POSTS
The only way i see coolant getting into your transmission fluid is there must be a leak between your radiator and the transmission cooler on the radiator.That's where i would check.
Sep 22, 2010 at 1:11 PM
