2001 Ford Explorer turn signal blues
DROCK11C
  • 2001 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 80,000 MILES
My turn signals started blinking quickly then not at all. I found a burnt front/right bulb and replaced it. Now everything works except the back right, which just blinks quickly. What do you think?
Tuesday, November 18th, 2008 AT 2:29 PM
DAVE H
  • 13,384 POSTS
You have a bad ground connection on the back light somewhere. Also check you haven't blew another bulb. The quick blinking is usually a sign of bad bulb?
Tuesday, November 18th, 2008 AT 5:24 PM
DROCK11C
So I used the truck for a few weeks while the turn signals worked intermitenly. Now I have no lights working in back, turns or brake.
Monday, December 8th, 2008 AT 8:31 PM
DAVE H
  • 13,384 POSTS
Do you have license plate lamps? These lamp's are all grounded @G414 ground point behind left rear quarter panel and @ ground point G200 behind left front kick panel. I would go for the rear ground point first?
Monday, December 8th, 2008 AT 8:58 PM
