2001 Ford Explorer tires
RON SHARP
  • 2001 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 116,222 MILES
If the tires I have on my explorer now are 235 75 15 and I put 205 75 15 on it what will be the effects and defects
Thursday, September 17th, 2009 AT 7:58 PM
  • 109,874 POSTS
It is a much smaller tire. It will have an affect on the handeling change the speedometer. If it isn't a recommend size, I wouldn't use it.
Sunday, September 20th, 2009 AT 1:56 PM
RON SHARP
Whould it effect the odometer milege at all and about the speedometer will it say I'm going faster than I really am
Sunday, September 20th, 2009 AT 2:33 PM
  • 109,874 POSTS
A yes to both. A smaller tire has to spin faster to go the same distance. I can't say how much it will change things, but the smaller you get, the more it will have an affect on the system. Also, you will be losing ground clearance. If that even matters to you.
Honestly, you sound like you are in the same boat as I am. Trying to save a buck any way you can. However, I really recommend staying with the manufacturers recommend tire size.
Sunday, September 20th, 2009 AT 7:56 PM
