2001 Ford Explorer sway bar link replace
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
NEWDOUG1958
Question My sway bar bolt broke at the top should the pin just fall out or do i have to remove from the nut still, the pin is bent and not allowing to come out
Aug 28, 2009 at 3:46 AM
  • 110,248 POSTS
It should come out, but chances are it is rusted and will require you to hammer it out. It the bolt has broken, there is nothing else holding it in.
Sep 10, 2009 at 3:39 AM
