2001 Ford Explorer Starter?
17,600 MILES • 6 CYL • 4WD • AUTOMATIC
MARSUN76
I changed out my starter a few weeks back and since then, my cars been a paperweight. The lights and everything work, but when I try to crank my car.. nothing.. not a sound. I had a friend check my fuse box while i tried to turn over my car and he saw that the 50 fuse (starter relay/ignition switch) keeps blowing. Is this due to a faulty wiring issue? Im lost and Im at day 28 with no car. Help please.
Sep 11, 2010 at 8:04 AM
WRENCHTECH
  • 20,760 POSTS
I would suspect that you have something wired wrong. Did you mess with the solenoid next to the battery?
Sep 11, 2010 at 8:34 AM
MARSUN76
no. only thing that my hands actually touched were th wiring harness, the starter and the battery.. Im trying to look at it and see where the wiring went wrong. This is my first starter change out so im kinda lost. Im running off of google and wiki information right now
Sep 11, 2010 at 9:00 AM
WRENCHTECH
  • 20,760 POSTS
You have a main power feed wire touching ground somewhere. Check the wires at the main post of the starter.
Sep 11, 2010 at 9:07 AM
