2001 Ford Explorer stalls/shuts off
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
P10BURE
whenever I put my truck into park after it being warmed up it shuts off/stalls. Its like I turned the key off (which at 1st I thought i did) no noises at all, just off. It just started doing this about a day ago, so maybe 4 times total. Thank you.
Nov 5, 2009 at 10:54 AM
BMRFIXIT
  • 19,053 POSTS
Can you keep it going by holding the gas peddle and raising the RPM
and if so check and suspect IAC
also check for vacuum leaks
and codes too
Nov 5, 2009 at 10:27 PM
