2001 Ford Explorer pcm
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
NICK99
pluged scanner in no power to scanner had ing. switch on rolled engine over still no readings on scanner is my pcm bad?
May 21, 2010 at 6:41 AM
  • 110,248 POSTS
Chances are that isn't the problem, but rather a loose connection. Have you checked the plug to the PCM? Also, I'm guessing that it won't start. Are you getting spark or fuel to the engine?
May 21, 2010 at 1:50 PM
