2001 Ford Explorer oil leak
44,000 MILES • 6 CYL • 4WD • AUTOMATIC
JFADA
there is an oil leak coming from the Rear Axle center ball, at the bottom. There is a gasket with about 12 screws the fasten the lid to the main part. does the gasket need to be replaced ?
Apr 2, 2009 at 6:20 AM
BLACKOP555
  • 10,386 POSTS
try a new gasket. be sure to put on rtv sealant on both sides of the gasket and properly torque the bolts.
Apr 4, 2009 at 9:29 AM
