2001 Ford Explorer misfire
155,322 MILES • 6 CYL • 4WD • AUTOMATIC
EDWIN_GMG
engine misfires but not at all times. already replaced spark plugs that were from factory and wires, checked for vacum leaks, it was good, also checked injectors with a ohm reader, readings were 17.0 except on 1 that was 15.4 was wondering if that is what is causing the misfire please let me know i would appreciate it thanks..
Nov 2, 2010 at 1:27 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
Nov 2, 2010 at 6:45 PM
