Replaced master cylinder as per instructions
Bench bled & line bled brakes
Pedal still sometimes fades after holding, almost like
ABS kicking in but no indication on dash.
Have rebleed system 3 times and still shows some air. System has crusie switch on cylinder & extra lower port for bleeding . Bled them 1st then wheels in correct order rr lr rf lf, np leakage detected anywere.
May be replacement cylinder bad??????
Oct 12, 2008 at 2:11 AM
