2001 Ford Explorer Engine light on
MMELYMUKA
Electrical problem
2001 Ford Explorer 6 cyl Two Wheel Drive Automatic
Engine light on. Had diagnostic completed but showed nothing. Can run for a while then all of a sudden, begins to shudder and can stall.
Tried to replace O2 sensor but still same.
Dec 18, 2008 at 4:05 AM
SERVICE WRITER
  • 9,123 POSTS
IF the check engine light is on. There will be a codes or codes stored the the pcm. Get them and post what you found.
Dec 18, 2008 at 4:33 AM
