2001 Ford Explorer Cyl Head
96,000 MILES • V8 • AWD • AUTOMATIC
SORINICU
I have tried to replace the original sperk plugs that where VERY rusted in. The spark plug on cyl #1 and #2 broke off but I was able to remove the leftovers with a bolt remover.
On the cyl #3, the bolt remover broke in the spark leftover and I cannot extract it.
How much (labor and parts) would be to replace the whole cyl head for a V8 5L engine?
May 31, 2010 at 9:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
labor will be approx. $450 , cost of head depends on if you go with brand new, used or reman head. a new one is around $800 ...
May 31, 2010 at 10:07 AM
SORINICU
Thank you! I'll check tommorow at the shops the actual quotes, but at lest I know what to expect.
May 31, 2010 at 1:15 PM
