2001 Ford Explorer Cyl Head
SORINICU
  • 2001 FORD EXPLORER
  • V8
  • AWD
  • 96,000 MILES
I have tried to replace the original sperk plugs that where VERY rusted in. The spark plug on cyl #1 and #2 broke off but I was able to remove the leftovers with a bolt remover.
On the cyl #3, the bolt remover broke in the spark leftover and I cannot extract it.
How much (labor and parts) would be to replace the whole cyl head for a V8 5L engine?
Monday, May 31st, 2010 AT 4:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Labor will be approx. $450, cost of head depends on if you go with brand new, used or reman head. A new one is around $800.
Monday, May 31st, 2010 AT 5:07 PM
SORINICU
Thank you! I'll check tommorow at the shops the actual quotes, but at lest I know what to expect.
Monday, May 31st, 2010 AT 8:15 PM
