2001 Ford Explorer Check Susp Light
104,000 MILES • 6 CYL • 4WD • AUTOMATIC
LLMWALL
Hi Guys. My 2001 Explorer XLT is running and ridding great . The check susp light came on about a month ago and since I am laid off from work I can't afford to get it looked at. There hasn't been a sign of a problem until now. Everthing is normal except the light and after I shut it off I hear a clicking sound coming from the relay box under the hood. A closer look and I find that the clicking is coming from the air suspension relay and the PCM relay. The sound alternates from one to the other each time it clicks. I am pretty handy and I might be able to fix it if I knew what it was. Is there a chance that it is a simple fix? Any hint I can get will be greatly appreciated.
Thanks,
Mike
May 5, 2010 at 7:46 AM
MERLIN2021
  • 17,250 POSTS
Do you have anyone with a scantool that reads B and C codes? This is unfortunately the starting point... Your system has a stored code(s). They will tell you what part needs inspection, Is the compressor running at all?
May 7, 2010 at 10:27 AM
