2001 Ford Explorer check engine light, fuel pump relay butt
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
TISHA25
My 2001 explorer has 2000 parts I was told but the truck wont start and it was cutting off when low on gas and finally wouldnt start back up. The check engine light isnt coming on and I was told it was a button on the passenger side under the glove box to reset something to get it to start again. The fuel pump was checked and wasnt bad. I was wondering if you could tell me if its a fuse and were the button might be, I cannot find it. Thank you
Mar 12, 2010 at 1:47 PM
  • 75,988 POSTS
The inertia fuel cut off switch is behind right front kick panel.
Mar 12, 2010 at 2:08 PM
