2001 Ford Explorer Car Won't Start
LVMONAT14
Electrical problem
2001 Ford Explorer 6 cyl Four Wheel Drive Automatic 176k miles
My car has many problems and I don't know where to begin. All I know is now it won't start. Absolutely nothing turns on.
1. It will sound like it's revving up and the RPM will shoot to 4 or 5 upon accelerating, but won't go faster, it will actually slow down and feel like it stalls. Then it will kick into gear and accelerate just fine (and I don't think automatics should have trouble switching gears).
2. I replaced the starter about three weeks ago because it was shot, so I don't think the problem lies here.
3. Just today I was pulling out onto the highway and upon accelerating the speedometer went rogue and started flying from 0mph to 70mph very fast. The car didn't actually go this fast or slow when this happened, it just jutted forward then slowed down, and repeated this until the speedometer stopped bouncing around and displayed the correct speed. I pulled in to a parking lot, shut off the car, and it died. But it didn't stay dead. My zombie car came back to life. I was able to turn the car back on after about 5 minutes and everything appeared to be normal; until I had to accelerate on the highway again. It repeated what it had done before, but this time seemed to slow down more. I got back home safe and sound, but now it's dead again. I haven't checked to see if it will start again.
4. I don't know if it's the battery or if it's electrical or even the engine. Again, all I know is that it's completely dead...for now.
Apr 24, 2010 at 2:25 AM
  • 110,251 POSTS
It does sound like a few problems. You may need a priest and not a mechanic (LOL).
Anyway, based on what you said, the car does start and run, just not right. Does the transmission feel like it's shifting incorrectly? Based on the speedo and the way you said the RPM's rev and you slow down, that problem sounds like a vehicle speed sensor (VSS). However, that won't cause it to shut the engine off.
As far as the engine dieing, has the check engine light come on?
Apr 24, 2010 at 2:21 PM
