2001 Ford Explorer Car rolls in park
155,000 MILES • V8 • 2WD • AUTOMATIC
YABADUCK
My car has been rolling in park which now has me having to put the park brake all the way to the floor to keep it from moving while I'm at work. Also, I have to start my car in neutral. What could be the problem?
Feb 25, 2009 at 10:41 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the shifter cable is out of adjustment or something is coming apart that controls the cable. First lift and support vehicle so you can get under it to inspect where the cable attaches to the trans.Be sure it is ok and nothing has broken.Next you will need to remove the lower shield so you can gain access to the steering column from under the dash.Inspect where the cable attaches to the column, some Explorers loosen up there and it can cause what you describe
Feb 25, 2009 at 11:34 PM
