2001 Ford Explorer Brakes slip/slide only when turning stee
94,000 MILES • 6 CYL • 4WD • AUTOMATIC
REELMAGIK
Recently, I noticed that when I pull into a parking space, the brakes slip, as if I were sliding on ice and it becomes difficult to stop. The brake pedal also feels as though it pushes in further when this happens, as if I'm losing vacuum pressure in the master cylinder or something. It only does it when the wheel is turned in either direction after a certain point...otherwise it seems to stop fine. It's very strange, and I just cannot seem to figure out why it only does this when the wheel is turned.
May 17, 2010 at 2:29 PM
  • 110,246 POSTS
Does it feel like the ABS is turning on?
May 18, 2010 at 1:19 AM
REELMAGIK
Yes, it does feel like the ABS is turning on.
May 18, 2010 at 10:28 AM
  • 110,246 POSTS
There is an ABS sensor on both front wheels at the end of the axle where it goes into the wheel hubs. Check the wiring to them. Chances are the wiring has been damaged and shorting the ABS when you turn, or the sensors / stator are dirty and actuating the ABS. Here is a picture of the sensor.
https://images.2carpros.com/forum/automotive_pictures/249084_Steering_knuckle_labels_WEB_1.jpg
Let me know if this helps or if you have other questions. Joe
May 18, 2010 at 1:50 PM
REELMAGIK
Thank you very much...I will check the sensors and wiring and see if that is the problem. I appreciate the response. I'll get back to you and let you know if that works.
May 19, 2010 at 8:58 AM
  • 110,246 POSTS
Let me know. That is the only thing at this point that makes sense to me because it only happens when you turn.
May 19, 2010 at 4:25 PM
