It is located in the front seating area, driver side, behind dash. It's mounted on steering column.
Here is what it looks like:
The flasher just unplugs and plugs in.
Dec 2, 2009 at 2:50 PM
TOKEN321
MEMBER
Thank You
Dec 3, 2009 at 9:51 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
The hazard-turn signal flasher is located under the dash next to the steering column. I've attached a picture below for you and circled it in red. Hope this helps and thanks for using 2CarPros.
