2001 Ford Explorer BATTERY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
AKING420
I HADNT DRIVEN MY CAR FOR A WHILE AND THE BATTERY HAD DIED. I HAD AAA COME OUT AND JUMP IT BUT WHEN THEY DID ALL THE LIGHTS EXTERIOR AND INTERIOR BEGAN BLINKING AND WOULDNT STOP HOW CAN I FIX THIS
Nov 8, 2008 at 7:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure you used the recommended battery size. Also, check the distilled water level inside the battery to ensure it is up to maximum level.
If this is all good, you probably just need to reset the computer. This can sometimes be a little tricky depending on your vehicle so I would suggest calling your local dealer to get instructions on how to do this.
Nov 8, 2008 at 7:29 AM
