2001 Ford Explorer Acceleration at high altitudes
2001 FORD EXPLORER
AIREDALES88
Engine Performance problem
2001 Ford Explorer Front Wheel Drive Automatic
Hi. I have a 2001 Ford Explorer Sport Trac. I've noticed that whenever I'm at fairly high altitudes that my truck starts having trouble getting over 40MPH. I have to basically push the gas pedal all the way down to get to a decent speed at which I can avoid getting run over on freeways. I know that this isn't good for my truck, but sometimes it's my only option at the current time.
The only answer I've been able to find is that my truck is so adjusted to the altitude where I live that it's unable to, has problems with, adjusting to the change.
Do you know what's wrong?
Aug 30, 2010 at 5:26 PM
  • 110,194 POSTS
Have the MAP sensor. Also, has the check engine light come on?
Sep 1, 2010 at 11:12 AM
AIREDALES88
No it hasn't, and I honestly have no idea what a MAP sensor is :(
Anything past oil changing and replacing a tire, I know basically nothing of cars.
Sep 2, 2010 at 2:17 AM
  • 110,194 POSTS
MAP is short for Manifold Absolute Pressure sensor. The manifold absolute pressure sensor provides instantaneous manifold pressure information. The data is used to calculate air density and determine the engine's air mass flow rate, which in turn determines the required fuel metering for optimum combustion and operation. Just a note, I ment to say MAF sensor which is a Mass Air Flow sensor. It does basically the same thing. It is connected to the air intake system. Here is a picture:
https://images.2carpros.com/forum/automotive_pictures/249084_5_61.jpg
Keep in mind, without the check engine light coming on, this is nothing more than a guess, but they are easy to install.
Sep 2, 2010 at 7:29 AM
