2001 Ford Explorer
TAHOE23SS
Brakes problem
2001 Ford Explorer 6 cyl Two Wheel Drive Automatic
how do i know if i need to replace my brake rotors?
Jan 1, 2010 at 8:21 AM
  • 110,248 POSTS
There is a minimum thickness that they can not go below. The minimum thickness should be stamped on the rotor and you will need a micrometer to measure them. Also, if the rotors are badly grooved or warped, chances are they will need replaced.
If you explaine your concerns, I may be better able to help.
Jan 1, 2010 at 4:43 PM
