2001 Ford Explorer
112,000 MILES • V8 • 2WD • AUTOMATIC
EV GODDESS
I am wandering what my problem would be if my car does not start right away in the morning when it is really cold. I replaced the battery, had a minor tune up at the begining of this year. It turns over and then it will start. I cleaned the cables to the battery, and changed the air filter. But i was told that it could be the Mass Air Flow sensor to cause my car not to start right away. I had the alternator and starter checked. So I just wanted to know if this could be my trouble with not starting. The battery indicator would be very low but when I cleaned the cables it went up but still having trouble. I just want to know if this could be the problem and why my car would not start right away in the cold mornings.
Dec 5, 2009 at 4:22 AM
BLACKOP555
  • 10,386 POSTS
what seems to be the problem.
slow cranking? no cranking? normal cranking just no firing up from the vehicle?
Dec 5, 2009 at 9:02 AM
