HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine
Symptoms
Not Running
SPONSORED LINKS
2000 Ford Explorer will not run in drive gear
JOHN LX
MEMBER
2000 FORD EXPLORER
6 CYL
FWD
AUTOMATIC
141,000 MILES
Need to know what the could be wrong my ford explorer die out when put in drive. It start back up find
Saturday, April 10th, 2010 AT 2:10 PM
KHLOW2008
MECHANIC
Hi John LX,
Thank you for the donation.
If the idling system is not working correctly, the engine can stall when shifted into gear.
What is the idling speed.
Does engine stall if you increase the idling speed slightly before shifting into gear?
SPONSORED LINKS
Sunday, April 11th, 2010 AT 12:27 AM
JOHN LX
MEMBER
1 POST
If I even hold foot on breaks and shilf into gear car still cut off while still idling
Sunday, April 11th, 2010 AT 7:26 AM
KHLOW2008
MECHANIC
Sorry, you did not answer my questions
1. What is the idling speed?
2. Does engine stall if you increase the idling speed slightly before shifting into gear?
3. Do you have rough running issues when idling?
4. Does shifting into reverse cause the engine to stall too?
5. Is the Check Engine Light indicating?
6. Was any repairs carried out prior to this occurring?
Sunday, April 11th, 2010 AT 2:17 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Turns Over But Won't Start
I Have A 2000 Ford Explorer, That One Morning I Went To Go To Work And Turned The Key And The Truck Acted Like It Wanted To Start But Wasn...
Asked by
tamachu
2000
FORD EXPLORER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
2000 Ford Explorer 4.0 Sohc Will Not Start
My 2000 Explorer Ran Fine Yesterday And I Parked In My Garage. The Next Day It Would Not Start. It Has Fuel But No Spark. I Have Tested The...
Asked by
gone13
2000
FORD EXPLORER
2000 Ford Explorer 2000 Ford Explore Sport 4wd Wont...
I Was Doin A Tune-up And Ran Into The Problem Of Not Reaching The Last 2 Spark Plugs On The Pass-side. So I Figured I Could Jack It Up And...
Asked by
mkstephens08
2000
FORD EXPLORER
Engine Not Starting
Explorer Will Turn Over But Never Crank If You Get Vehicle To Crank In Morning It Will Crank Fine All Day, Let It Sit Overnight Might Crank...
Asked by
sgrant
2000
FORD EXPLORER
2000 Ford Explorer Xlp
Car Hasn't Given Me Any Trouble. Went Out For Dinner Last Night Came Out Of Restaurant And Car Would Crank But Not Start. Got A New Starter...
Asked by
punkin38
1 ANSWER
2000
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
