2000 Ford Explorer Where is the lower port?
JOHNPIERCE
  • 2000 FORD EXPLORER
  • 4 CYL
  • 4WD
  • 71,000 MILES
I am trying to refill my air conditioning. I can only find one port to put the coolant in. I don't know if this is the lower port or not.
Monday, May 5th, 2008 AT 8:11 PM
BOBO234
  • 8 POSTS
I hope that you are not trying to put engine coolant into your air conditioning system! These are 2 different and seperate systems. If you don`t understand the difference maybe you should take to a professional before you end up causing more damage.
Monday, May 19th, 2008 AT 2:07 PM
