2000 Ford Explorer violent shake when turning
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
WENDYLESSARD
no shake until we replace brakepads,rotors,..now we took out cv left hand shaft and it looks fine...balljoints,tye rod ends look fine,ball joints play 1/8",had to heat rotors to get them off but we onkly heated rotors in stud area..now a violent shake when turning
Mar 29, 2009 at 1:25 AM
MERLIN2021
  • 17,250 POSTS
WHEEL BEARINGS Turn off air suspension switch (if equipped). Switch is located behind right rear quarter panel. Raise and support front of vehicle. Remove wheels. Reinstall 3 lug nuts to secure rotor to hub. Check hub nut for correct torque. See TORQUE SPECIFICATIONS . Using a dial indicator, measure axial end play at hub. Maximum axial end play is .003" (.08 mm). If reading exceeds specification, replace wheel bearing assembly. © 2008 Mitchell Repair Information Co., LLC. Page 1 of 1 FRONT SUSPENSION - 4WD TORSION BAR -2000 Ford Explorer 3/29/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
Use of heat may have ruined the hub bearing!
Mar 29, 2009 at 1:29 AM
